2wd hub
Old Apr 25, 2008 | 07:44 AM
rinus_2005's Avatar
rinus_2005
Default 2wd hub
is a 2wd cosworth wheel hub the same as any other 2wd wheel hub?
(besides the abs sensor)
why? I have now 4wd hubs, which i'd like to replace for 2wd type, (having a new set of shocks) and i don't need the abs.
Or should really look out for some 2wd cossie types?
regards, Rinus
Old Apr 25, 2008 | 12:27 PM
The cossie ones are different to any other 2wd hub, in the area at the base of the strut, in a std 2wd it is hollowed out and sculpted but on a cossie it is much thicker and stronger, lug spacing is the same though just the cossie lugs are tapped out to take the caliper bolt whereas std 2wd hubs are just a hole as bolt passes through.
4wd hubs are different to 2wd, and they use thicker strut bodies as well.
Depending oin which 2wd cossie hubs you have the tca fitting will vary as well.
Old Apr 26, 2008 | 03:47 PM
rinus_2005's Avatar
rinus_2005
thanks, i'll look out for oe 2wd cosworth items then.
fordrallycar
Sep 30, 2015 07:57 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
jc1989rs
Sep 5, 2015 08:09 PM
