were does this plug go?? **FEW PICS**
Old Apr 22, 2008 | 08:36 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default were does this plug go?? **FEW PICS**
Im havin trouble gettin my rs to run after putting the engine bk in, it starts but cuts straight out, no fuel coming out the inlet injectors only cold start, i cant seem to find were this clip goes, any ideas?
also in the last pic, are they the right way round yellow n blue?
cheeRs
Old Apr 22, 2008 | 08:45 PM
blan77's Avatar
blan77
it goes to the amal valve but in the picy there is no amal valve ,the pipe which looks to be blocked off with a bolt also goes to the amal valve
not sure about the blue and yellow plugs will have to go look , if you havent stripped the wires ,its a good indication that they will only reach one way round ie, blue plug longer / shorter than yellow
hope this helps
Old Apr 22, 2008 | 08:52 PM
mercury grey minter's Avatar
mercury grey minter
That plug goes to the AMAL VALVE.You don,t need it as it looks like you have got a bleed valve set up.
And yes BLUE and YELLOW plugs are in the right place.
Old Apr 22, 2008 | 08:55 PM
JamesH's Avatar
JamesH
Amal valve?
JamesH's Avatar
JamesH
D'oh beaten to it
Old Apr 22, 2008 | 11:07 PM
TuRbO-CaB-LaD
cheers lads
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
