chatter 2wd saph
is it just a case ov removin standard dump valve and blockin the pipes also wat to do with the other pipe from amal (althouth amal not used)
would there be any probs as im runnin 16psi
thanks spen
thanks spen
eh?amal valve doesnt go to the dump valve! no probs at all,just blank off the hole(broomstick handle worked for me!)and use the vaccuum line for boost gauge or blank it off with a screw or summit,then youll be away! i used it on a t34 at 34 psi so 16 should be ok mate!
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
