Rear suspension arms
Old Apr 21, 2008 | 04:51 PM
haz87's Avatar
haz87
Default Rear suspension arms
Mine are worn to buggery and i know theres barely any good sets left as the bushes aren't replaceable.
What are the best polybushes to use? I know you have to retain the original metal sleeves, but how the hell do you get the new polybushes in?
Cheers,
Harry
Old Apr 21, 2008 | 07:18 PM
anodised's Avatar
anodised
you could burn them out
i cut part of the rubber off put a metal cup over it with a long nut and bolt and pulled it out
Old Apr 21, 2008 | 07:20 PM
moesin2005's Avatar
moesin2005
if you use powerflex u have to take the sleeves out which is a pain in the arse best to get someone with some burning gear to heat them and they should come out easy enough or u could use flo flex as they offer 2 types ones that take the sleeves out or ones that leaves them in but these are not that good quality but cheep
155lee
Oct 27, 2015 04:55 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
Tony W
Sep 9, 2015 12:08 PM
