whats the best spring rate for coilovers
best sring rate and lenth on the back of a saff for every day use the ones i got on at the moment are well hard
allan,on my 3dr i use 300ilb x 10" front springs and 220ilbx12" rears though i find the rears to short and hard as it skips on bends and coming out of roundabouts so changing to 180 ilb rears x 14" ,
cheeRS stu
cheeRS stu
thanks lads i dont know the spring rate thats on them as i brought them second hand they are group a tarmac set up with rose joints but if i push down on the boot it dont move a mm and on driveing on normal roads its bang bang bang all the time and its pissing me off
cheers ian going to order some springs tomorrow from burton and see what they advise its probly me getting old but when you drive a company car all week then get in the cossie its like a bean tin down a cobled road
Originally Posted by Rs Gus
i have 350lb 10" fronts and 250lb/ft rear 12" and matched damping rate they are gaz ask matt he has been in and i have the damping on half
impressed
go for the longest spring you can fit , this way you will get the poundage you require spread out over a long distance rather than being squashed into a short spring , i would recommend a good forrest setup for the road , but as above it depends on your damping rates as well , is yours 2wd or 4wd ?
what do you mainly do with it ? , road car / track car ?
for a good fat road i would say approx between 180lb to 280lb dependant on use and damper rates for the front (dependant on transmission) between 300lb and 400lb also dependant on use and damper rates
if youve got pukka bilsteins then if you take the insert out there will be a part number on it that you can get the rates from
hth
mark
p. my car has 180lb on the rear and croft was no problem and i dont run any anti-roll bars
hth
mark
SMILER258
Sep 28, 2015 09:04 AM
Adam Graham
Sep 6, 2015 06:04 AM
