Hissing while bleeding brakes
Old Apr 16, 2008 | 09:27 PM
mentalasanything's Avatar
mentalasanything
Default Hissing while bleeding brakes
Good evening all, hope we are all keeping well!
I have a quick question. Does anyone else get a hissing noise from the master cylinder area whilst they bleed the brakes on their RST's?
I noticed it when I did my front and rear brake conversions but thought nothing of it. Is this a problem or something that naturally happens?
Cheers in advance,
Lee
Old Apr 17, 2008 | 05:26 AM
If you are getting it all the time(engine off) it would rule out the vacuum being released which normally causes this, or you just have good hearing!!
Old Apr 17, 2008 | 07:02 AM
mentalasanything
Well, it doesn't happen when the engine runs, just when it's off and bleeding the brakes. It's quite loud too.
Old Apr 18, 2008 | 09:14 PM
mentalasanything
Anyone???
Old May 16, 2008 | 05:34 PM
R6Franky's Avatar
R6Franky
Tried bleeding mine today and found the servo hissing. Still haven't managed to get a pedal but I'm glad I can rule this out as the cause. Must just need to pump a hell of a lot more fluid through the system.
Dan
Old May 18, 2008 | 05:11 PM
moesin2005's Avatar
moesin2005
mine hissed then fluid started to run down the servo
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
