4wd Turbo onto 2wd Manifold
I have a T28 from a small turbo escort and I'd like to fit it to my 2wd engine.
How do I rotate the exhaust housing, it is simple a case of undoing the 6 bolts, turning it and re-bolting it up or is there some magic involved.
You need an actuator mounting bracket and turbo damper mount, but yes is that easy.
Cheers Mike
It has the Actuator mount on it, which again I presume I can just un bolt and move round one position
Hadnt thought about the turbo damper mount, guess I'll have to rob that off my T34...
The T28 shouldnt be a problem it was removed from a Small Turbo Escort when it was almost new... the T34 may be a different box of frogs as thats been on my motor for 4 or 5 years
May 31, 2016 09:28 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
13
Aug 31, 2015 06:02 PM
lockie
Jul 31, 2015 10:03 PM
