Big Breaks
Old Apr 16, 2008 | 10:36 AM
killa_paul's Avatar
killa_paul
Default Big Breaks
Ive got a 89 saph, and its been off the road while ive been rebuilding it, ive decided to uprate the breaks but im not sure what to go for, i have 17" kahns on it do i go 4pot 6 pot.
any makes and suppliers would be appreciated...so all help welcome .
Old Apr 16, 2008 | 10:51 AM
dojj's Avatar
dojj
Resident Wrestling Legend
depends on which rims you've got as to what you can fit underneath them really
so which rims have you got?
martin reyland of nuts rs do this sort of thing so you could try asking one of them
Old Apr 16, 2008 | 12:00 PM
killa_paul's Avatar
killa_paul
Default Big Breaks
There Kahn RS-S 17" im sure a 330 dick would fit under them.
hope this helps to help me find what breaks to get...or i will just have to get different wheels to accomadate it lol
http://www.wheelsnthings.com/acatalog/KahnRSS.jpg
thanks
Old Apr 16, 2008 | 09:27 PM
tichy.cosworth's Avatar
tichy.cosworth
Old Apr 17, 2008 | 03:58 AM
R5FORD's Avatar
R5FORD
Tarox 6pts 330mm disc
Old Apr 17, 2008 | 05:10 AM
Depends on BUDGET as well.
You could always get brackets made to use 325mm FRS discs with your calipers, which will give you a sizeable step up in performance due to leverage.
Old Apr 17, 2008 | 07:25 AM
killa_paul's Avatar
killa_paul
Where supplies these...can anyme supply some god websites ?
Old Apr 17, 2008 | 07:43 AM
R5FORD's Avatar
R5FORD
go throug PJ Motorsport..
www.pjmotorsport.com
but be prepared to wait as he isnt the fastest
Old Apr 17, 2008 | 10:49 AM
killa_paul's Avatar
killa_paul
looked on the sight can only find he ap 4pots for the 2wd saph ....
Old Apr 17, 2008 | 11:36 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
I would not touch Tarox, AP or Brembo are the way to go. Here's my number 0121 458 6010 call me if you are interested in a brake kit.. Ł1300 + vat 330 4 pots or Ł1400 plus vat 362mm 6 pots Both use AP discs and calipers.
Old Apr 17, 2008 | 11:43 AM
rsnissan's Avatar
rsnissan
Martin have you tried any of your kits under the CXN's yet?
Old Apr 17, 2008 | 11:52 AM
Martin-Hadland
Not under 7.5" fronts but have fitted 330 4 pots under 8" fronts.
Old Apr 17, 2008 | 12:11 PM
killa_paul's Avatar
killa_paul
thanks for the help... dunno if the 362 6 pots would fit under my rims, is here a way to use 6 pots and 330 disks ? thnks
Old Apr 17, 2008 | 01:21 PM
Martin-Hadland
Yes call for info
Old Apr 17, 2008 | 04:10 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Although the FRS Brembo callipers are pretty good, the FRS one piece discs are not really up to hard use, as they are unable to adequately dissipate the heat from a 1250kg car. Even the Focus warps it's discs on track, so a reasonably powered Sierra would do the same.
Obviously if the car wasn't going to be used on track, then this wouldn't be an issue, but them again, the standard items on a 2wd are good enough for fast road use if overhauled and braided hoses, good fluid and pads used, so you don't even need to go to the expense of that.
If you were going to use the FRS set up, then you would want the AP two piece brakes like Christian has put on his Escort RS Turbo - but then it's not a cheap option any more.
Brakes are a tricky thing to get right - doing it half way usually ends up with having to pay out twice (I found out the hard way on my own Sapphire all those years ago ), so always best to save up a little more and get the ones that will do the job in hand.
Old Apr 17, 2008 | 05:41 PM
jaimesdna's Avatar
jaimesdna
how about these kits i keep seeing about useing evo brombos & two piece 330mm disks. are these any good for a 400bhp road saff?
Old Apr 17, 2008 | 06:35 PM
Wayne Ash's Avatar
Wayne Ash
ive got 7.5inch on mine and i had to use a 4mm spacer to clear the caliper
Old Apr 18, 2008 | 08:41 AM
killa_paul's Avatar
killa_paul
Yes call for info
Ok thanks fella will give you a tincle this afternoon
Old Apr 18, 2008 | 08:48 AM
Mike Rainbird
Caraholic
As long as the disc is of sufficient quality and that you use suitable pads .
Old Apr 18, 2008 | 10:59 AM
Yura's Avatar
Yura
What calipers FRS are use? 2-pot?
Old Apr 18, 2008 | 11:33 AM
Mike Rainbird
Caraholic
Four-pot Brembos.
Old Apr 18, 2008 | 04:10 PM
costina's Avatar
costina
Live long and prosper!!
i run a compbrake 350mm kit using Brembo calipers
Not as cool as AP's but a good cheaper option
Paul
chowfornow
14
Jan 5, 2019 09:01 PM
stevecfrst1
Sep 30, 2015 05:18 AM
