Binding caliper
Old Apr 15, 2008 | 01:35 PM
capri280's Avatar
capri280
Default Binding caliper
I have a binding caliper at the moment on one side at front
Is there a solution to this or do i just buy a new caliper rather than mess about with it
Old Apr 15, 2008 | 02:19 PM
Depends how old it is as to whether to mess with or not.
The seals are genrally square cut to effect knock back where brake piston/pad is pulled off the disc after application, but the seals go hard, pistons rust etc.
You can do DIY no problem parts can be got from the likes of BIGGRED.CO.UK, he is very reliable, and cheap as well.
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
