s1 brakes
Old Apr 13, 2008 | 08:35 AM
moesin2005's Avatar
moesin2005
Default s1 brakes
haveing trouble getting a solid pedal has 4x4 cos front calipers to front with new pads and new cylinders shoes and springs to rear any body help
Old Apr 13, 2008 | 09:14 AM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
just keep bleading them mate, rst's havent got the best pedal to start off with.
mine has a bit of travel then is quite hard
Old Apr 13, 2008 | 11:08 AM
moesin2005's Avatar
moesin2005
can get a bit of pedal but when i drive the car and brake the pedal hits the floor
Old Apr 13, 2008 | 11:13 AM
jonnyrsturbo
ahhhhhhhhh thats not good. any leaks?
Old Apr 13, 2008 | 11:48 AM
moesin2005's Avatar
moesin2005
give me a clue as to where the leaks could be
Old Apr 13, 2008 | 11:59 AM
jonnyrsturbo
flexi's
union's
any of the main pipes
check under the car after pumpin the pedal if there is any puddles!
or just keep bleeding them
Old Apr 13, 2008 | 04:21 PM
fonfe's Avatar
fonfe
i had this problem and soved it by bleeding the brake for AGES! must of put at least 6ls of fluid through the system. still have a bit of travel then pedal goes hard, you just get used to it. it will go to the floor when your drivign because you have the engine running to have manifold pressure assisting the servo. just keep bleeding is all i can suggest!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
