compression
Old Apr 13, 2008 | 08:24 AM
ReneRST's Avatar
ReneRST
Default compression
did a compression test because it seems that he was running on only 3 cylinder.
and the result was 160 - 149 - 35 - 150psi , the 3 cylinder is the problem
what is it valve, piston
Old Apr 13, 2008 | 09:07 AM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
could be a number things, its a case of head off!
Old Apr 13, 2008 | 10:10 AM
sm's Avatar
sm
take the head off and get it checked out, if all is ok with it and the piston looks ok from the top then its more than likely that the side of the piston has cracked, this is what happend to mine number 3 had 30 psi all the rest had 160psi
Old Apr 13, 2008 | 11:15 AM
jonnyrsturbo
mine had tottally melted down the side of piston 2 and 3
Old Apr 14, 2008 | 10:18 AM
JamboRS's Avatar
JamboRS
focus rs 1672
probably detted and cracked the ring lands just like pic above
been there.............twice lol
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
