COIL WIRE
Old Apr 12, 2008 | 04:41 PM
BRI308's Avatar
BRI308
Default COIL WIRE
I Have Just Put My Engine Back In My 2wd Sapphire Cossie ,dropped The Engine Loom On Top Reffited All The Plugs On All The Connectors Come To Put The Leads On The Coil And There Is Only One ,a Green With A Block Connected To It.should The Other One Be In The Same Loom Or Does It Come Out Of The Cars Main Loom ? Many Thanks
Old Apr 12, 2008 | 06:48 PM
jon@work's Avatar
jon@work
black/yellow in the same loom
Old Apr 13, 2008 | 06:43 AM
BRI308's Avatar
BRI308
Default COIL WIRE
Thats Out Of The Engine Loom ,not The Car Loom ? Is That Right John,thanks
Old Apr 13, 2008 | 07:32 AM
coswurv's Avatar
coswurv
i had this problem yesterday when fitting a 2wd loom to my project car, just tie into the black and yellow wire that runs to the ign amp, its only a ign live so dont panic.
Old Apr 13, 2008 | 11:49 AM
BRI308's Avatar
BRI308
Default WIRE
Thanks To You Two ,its Up And Running
Old Apr 15, 2008 | 01:23 PM
coswurv's Avatar
coswurv
spot on mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
