converting to ofab from xr3i efi
Old Apr 11, 2008 | 01:36 PM
FULLBORE's Avatar
FULLBORE
Default converting to ofab from xr3i efi
ive sort of worked out how to wire in the supressor/map sensor. Thing is on the ofac map sensor plug the black/brown wire (ecu pin26), do i wire this directly to the black/brown wire on the ofab map sensor plug?
and ive worked out that i run the brown/yellow and brown wires through the suppressor? is that correct?
ive looked at rsbible and it isnt really clear enough and i dont want to damage my ecu.. This is all thats stopping me from my car running so help asap would be most helpful.thanks
Old Apr 11, 2008 | 01:48 PM
FULLBORE's Avatar
FULLBORE
or even if someone knows who i should speak to......as working it out to run through the supressor,only two wires go to the ofab map sensor plug.....the yellow and the brown/black so where does the brown wire on the plug go to????im getting really confused!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 13, 2008 | 12:00 PM
FULLBORE's Avatar
FULLBORE
anyone??? has no-one ever done this conversion.....or am i the first lol
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
dms04
Sep 11, 2015 01:57 PM
