18" wheels & Konis.
Old Apr 10, 2008 | 12:19 PM
ECOS95's Avatar
ECOS95
Default 18" wheels & Konis.
Has anyone else had an issue with running 18" alloys with an offset of ET25 with a koni suspension kit ? Since fitting mine I've found that the wheels foul the Spring cups & even with gentle persuasion with a large hammer they still won't fit correctly.
Has anyone elses come across this & how did you get around it.
Thanks for any help.
Old Apr 10, 2008 | 12:47 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
What tyres are you running?
Even with 225/40s you have to do this to the spring cups:
If you're running bigger tyres, then I don't think you will get them to fit. This is why we run ET15 offset....
Old Apr 10, 2008 | 12:49 PM
ECOS95's Avatar
ECOS95
Hi Mike 225/40zr18.
Old Apr 10, 2008 | 01:18 PM
Mike Rainbird
Caraholic
Hi Mike 225/40zr18.
A bigger hammer is required .
Old Apr 10, 2008 | 01:20 PM
ECOS95's Avatar
ECOS95
Cheers Mike I'll give it another go.
Old Apr 10, 2008 | 03:14 PM
THE RADMAN's Avatar
THE RADMAN
you really need et of 18 ,and then theyre really close with 225/40 even when modded,if you have et 25 i dont think you will get clearance at all without using some small spacers or coil overs
Old Apr 10, 2008 | 03:30 PM
ECOS95's Avatar
ECOS95
I tried a 5mm space but it doesn't leave much of the hub left for the wheel to sit on. I've tried a friends wheel & that fits ok after a bit of modding to the spring cup & there Et18.
I caren't believe Koni caren't get this right from the factory.You'd expect Et25 downwards would fit without fouling.
Old Apr 10, 2008 | 07:44 PM
sheerline's Avatar
sheerline
i have 18s , same size tyres , same ofset , and konis ive got spacers on that are bolted to the hub this spacer has its own wheel nuts and enough hub lip , they came with the car when i bought it ,so unsure who supplies them ,but this setup works a treat ,someone must sell them
Old Apr 10, 2008 | 07:58 PM
ECOS95's Avatar
ECOS95
Originally Posted by sheerline
i have 18s , same size tyres , same ofset , and konis ive got spacers on that are bolted to the hub this spacer has its own wheel nuts and hub lip , they came with the car when i bought it ,so unsure who supplies them ,but this setup works a treat ,someone must sell them
Thats just what I need, I'll do a search on the web.The cheap ones from Halfords aren't much cop.
Thanks for the advice.
Old Apr 10, 2008 | 09:05 PM
THE RADMAN's Avatar
THE RADMAN
you must have at least 15 mm thick spacers then to do it this way
Old Apr 11, 2008 | 07:44 AM
ECOS95's Avatar
ECOS95
Eibach do them starting at 10mm which would bring my et to 15. I see what your saying though.
Old Apr 11, 2008 | 08:56 AM
Mike Rainbird
Caraholic
Chris (AKA Cossymad) at Carnoisseaur can do these at a very good price .
E-mail Address(es): CARNOISSEURSOUTH@aol.com
Old Apr 11, 2008 | 10:00 AM
ECOS95's Avatar
ECOS95
Cheers Mike.
Old Apr 11, 2008 | 12:27 PM
ECOS95's Avatar
ECOS95
Spoke with Chris & he can sort me out with the spacers I need, top man ! Thanks for everyones help, i'd of been gutted if I had to sell the wheels.
Old Apr 11, 2008 | 12:31 PM
Mike Rainbird
Caraholic
Cool .
Any pictures of them to see why you are so set on keeping?
Old Apr 11, 2008 | 12:33 PM
Kelv's Avatar
Kelv
Almost there!
they are the white comp MO's that i bought from Martoon.
Old Apr 11, 2008 | 01:30 PM
cossymad's Avatar
cossymad
He was trying to fit these
We sorted them out!!!
Old Apr 11, 2008 | 01:55 PM
ECOS95's Avatar
ECOS95
Cool .
Old Apr 11, 2008 | 02:17 PM
Mike Rainbird
Caraholic
I hope you're buying four spacers .
Old Apr 11, 2008 | 02:36 PM
ECOS95's Avatar
ECOS95
Oh Yes. Don't want it looking like a tractor.
Old Apr 11, 2008 | 02:37 PM
Franco's Avatar
Franco
Whites SOOOO last year!
Old Apr 11, 2008 | 02:59 PM
ECOS95's Avatar
ECOS95
Old Apr 11, 2008 | 03:03 PM
Franco's Avatar
Franco
Have fun cleaning them my Friend!...................
I loved it!
Old Apr 11, 2008 | 03:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
i am currently running a set of 215/45/17's on an ET45 offset that clear the struts (escos struts and 2wd hubs) yet i needed spacers for the rears but not the fronts
all bolted to a sierra with just a few arch rubbing issues
expected?
or not?
Old Apr 11, 2008 | 04:19 PM
Cossie-Lee's Avatar
Cossie-Lee
does this problem only happen with 18" wheels and konis? I was going to go for 17" wheels but have just been offered a set of 18" OZ Super Ts.
Old Apr 11, 2008 | 05:12 PM
ECOS95's Avatar
ECOS95
I loved it!
Your not wrong there. I should get them sprayed Grey to hide the dust !!
Old Apr 11, 2008 | 05:15 PM
ECOS95's Avatar
ECOS95
If you have ET25 yes. Even with ET18 I had to modify the spring cups with a large hammer.
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
