flank thickness standard brakedisks
Old Apr 9, 2008 | 04:21 PM
Spotmatic's Avatar
Spotmatic
Exclamation flank thickness standard brakedisks
Hello,
I need to know the flank thickness of the standard front brakedisks. By the flank i do mean the part witch attatches to the wheelhubs. I can't mesure it myself as i've sold my front brakesetup.
Thank you in advance,
Mark
Old Apr 10, 2008 | 04:11 PM
Spotmatic's Avatar
Spotmatic
Does nobody have a set standard brakedisks laying around? I need this size to calculate the correct size of wheelspacers i would like to buy today. I currently have Godspeed brakedisks with a flank thickness of 15mm
Old Apr 11, 2008 | 10:23 AM
Spotmatic's Avatar
Spotmatic
I've bought an AP Racing BBK from Godspeed, the diskflanks of these disks are 15mm thick. This means i will need to buy different wheelspacers for my Group A (ET33) wheels. The original brakesetup has already been sold. So if someone can mesure this for my i can order the correct wheelspacers.
Thank you!
Old Apr 12, 2008 | 10:46 AM
Spotmatic's Avatar
Spotmatic
Nobody?
Old Apr 14, 2008 | 02:15 PM
dojj's Avatar
dojj
Resident Wrestling Legend
15mm ?!?!?!?!?!?!?!
they should only be about 8mm thick from what i can remember mate, possible even thinner than that
your wheels are going to be MILES out
Old Apr 14, 2008 | 02:38 PM
Dave Henshall's Avatar
Dave Henshall
this site has a LOT of useful info......
http://www.national-auto.co.uk/catafiles/brake/nbd.pdf
Old Apr 14, 2008 | 06:57 PM
Spotmatic's Avatar
Spotmatic
Originally Posted by dojj
15mm ?!?!?!?!?!?!?!
Yes they are, in my case not a problem as i run group A (ET33) wheels. The problem is that i don't know witch wheelspacers to use to get to ET15-ET18.
Thank you! Pity that the size needed is not quoted.
Old Apr 16, 2008 | 07:52 AM
Spotmatic's Avatar
Spotmatic
No one?
Old Apr 17, 2008 | 06:49 PM
Spotmatic's Avatar
Spotmatic
Unhappy
Really desperate to find this out.....
Old Apr 18, 2008 | 08:52 AM
NUTS RuS's Avatar
NUTS RuS
I will measure it today if you still need the info
Old Apr 18, 2008 | 10:48 AM
Spotmatic's Avatar
Spotmatic
That would make me very happy indeed! Thanks!
Old Apr 18, 2008 | 11:18 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If you're saying you have spacers built in to the bells of 15mm, that is perfect to achieve the offset that you want with ET33 wheels. The higher the number, the more INSET the wheels are, so if you have 15mm spacers, then this would make the wheel offset equivalent to ET18 (subtract the spacer width from the wheel ET to get the new ET), which depending on the width of the wheels, is perfectly adequate (unless of course the car is already a wide-track Grp A car, which is what the ET33 wheels were designed for) .
So in answer to your question, another set of 15mm spacers should do the trick, but you will need these front and rear. Eibach do some this thick and Cossymad off the BB can supply them if you can' get them in your country.
Old Apr 18, 2008 | 11:24 AM
Spotmatic's Avatar
Spotmatic
Thanks for your reply, i'm not saying that the bells have 15mm spacers but the bells are 14.5 mm thick. Thats why i need to know the size of the standard disks to calculate what spacers i do need.
Mark
Old Apr 18, 2008 | 11:31 AM
Mike Rainbird
Caraholic
To achieve the correct offset that you want with "normal" thickness bells, you need 15mm spacers .
Old Apr 18, 2008 | 11:39 AM
NUTS RuS's Avatar
NUTS RuS
Flank thickness on the ones I have here is 8mm
Old Apr 18, 2008 | 12:15 PM
Spotmatic's Avatar
Spotmatic
Thumbs up
Thank you! This means i will have to buy 10mm spacers at the front and 15mm at the back! thank you very much!!!
Old Apr 18, 2008 | 12:23 PM
Spotmatic's Avatar
Spotmatic
Mike, how thick are the original AP bells?
Old Apr 18, 2008 | 12:24 PM
NUTS RuS's Avatar
NUTS RuS
No problem
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
