saph whinning?
Old Apr 8, 2008 | 04:29 PM
Cals_cossie's Avatar
Cals_cossie
Default saph whinning?
my saphire cosworth 4x4 if whinning when driving, but when cluth is in it is fine, replace the bearings> or be aswell new clutch?
Old Apr 8, 2008 | 06:18 PM
Just first make sure the cable is not loaded slightly as this will do it, just pull up pedal and push the quadrant forward about 1 " and release then a few presses later it will self adjust.
If it still whines, I personally would put up with it if only slight, but your call, if a loud whine/drone I would replace anyway.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
landaqmabba
Sep 15, 2015 07:16 PM
