2wd TPS problem
Old Apr 8, 2008 | 10:27 AM
coachworz's Avatar
coachworz
Default 2wd TPS problem
hi,
I have just change the TPS but notice there is over fueling/ hesitation on part throttle between 1500 to 2000 rpm.. there is black smoke presents too. but once the tps is disconnected the problem is gone but without the tps the engine tends to die off when the rpm drops... any idea why?
Old Apr 8, 2008 | 11:28 AM
Are you sure it is a 2wd TPS you fitted ?
Old Apr 8, 2008 | 11:52 AM
RS Juto's Avatar
RS Juto
i had the same problem, changed my plenum but forgot to change the TPS - DOH.
Old Apr 8, 2008 | 02:57 PM
coachworz's Avatar
coachworz
the TPS is fp01 is that the correct one? its black color.
Old Apr 8, 2008 | 03:24 PM
AndyPen's Avatar
AndyPen
i dont know the number offhand but my 2wds are both browney red in colour??
Old Apr 8, 2008 | 04:29 PM
Ryan's Avatar
Ryan
TPS used with L1 & L6 ECU = PF01 (Red in colour) 2wd
TPS with L8 & P8 ECU's = PF09 (Generally Black, but early 4x4 ones were also red) 4x4
Number is embossed on the TPS casing
Old Apr 8, 2008 | 10:37 PM
coachworz's Avatar
coachworz
mine is black but marked as PF01.....
Old Apr 9, 2008 | 06:15 AM
Replacements could be black on 2wd as made by different contractor, so as PF01 it is right.
Old Apr 9, 2008 | 01:33 PM
coachworz's Avatar
coachworz
was told the chip is too rich is no good and need stand alone ecu....
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
jc1989rs
Sep 5, 2015 08:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
