New PROALLOY Fuel tank, Finished piccys.... JUST AMAZING!
Look at that badboy
Soooooooooooo lovely. Almost a shame to fit it in the car!
Very very very pleased. MASSIVE thanks to Wayne and Alex.
This will be all fitted by monday and so will update with some in car shots then
www.proalloy.co.uk
www.proalloy.co.uk
Originally Posted by Gav Diamond
Think it would look better in my car
Looks wicked mate
Looks wicked mate
I think you NEEEEED a tank like that mate. Give Wayne a bell...Sierra is going to be tidied up like yours though and is going to look very very very nice for next year!
Next step is ripping the dash out and re-doing all that and rewiring all the fuses to the centre console..
Its all going to look
Looks wicked mate
Looks wicked mate
I am tempted, pm how much they are.
You want to get the dash flocked i recon as i am in mine, looks wicked
I just need some of them new MO's now, do you think 9x18 will go on the back?
Good luck with the car mate, im hopin to be on track for the Bedford day in Feb
Edited to say sorry i woke you up saturday, but 3.30pm in the afternoon come on mate,lol
With these types of tanks with the foam do you still need to run a swirl pot to stop the surge issues?
I was going to run 2 Holley pumps as lift pumps feeding a swirl pot with 2 GrpA pumps feeding to the engine.
With this tank how will it run, can i run it in the same way?
how much do them tanks cost roughly???
cheers
marc
Even the std underslung Sierra Tank with its baffles in , suffers from fuel surge under heavy cornering , not what you need as the engine momentarily runs out of fuel and goes lean . So if you go above the std position and force feed the fuel system then you will need a swirl pot big enough to remove surge in ALL conditions , this principal applies to any fuel system and any situation especially as a " Belt and Braces " factor.
Whether the tanks Foam Filled or not , makes little difference to this , my tank has a 2 1/2 litre Gated collector in the tank , but i fitted a Swirl pot just in case !
regards
Tony
regards
Tony
Yes Tonys right! I always used to run a seperate little tank on the Sierra and ProAlloy are making a 2gallon Accumulator for this one as well. It sits below and is gravity fed. This is a mock up of how it will look Gav.
All the gump on the right is the old set up and will be going. The new install should look very tidy. Gav just copy this mate. No lift pumps needed and I'm using just ONE Fuel pump! much better
Originally Posted by TIFF-C20WTH
Whats the buttons on the top for Lee???????????????????
Is the Sierra having a make over on the outside too?????
Okay - that's very tasty.
Am now considering selling mine as it's a rally one, and heavily biased to one side of the car, to allow the spare to sit in the boot too.
Wayne - can you PM me a price - how much am I looking at for a saff to fit in here:
Very impressed!
Very impressed!
RichardPON,
ok chap, I will get my business partner Alex to contact you tomorrow if thats ok.. looks like one very similar to lee' s will fit
if you look on our web site
www.proalloy.co.uk
in the new products section you will get an idea on cost...
www.proalloy.co.uk
