what oil to use when running in?
Old Apr 7, 2008 | 04:42 PM
rst in breaking's Avatar
rst in breaking
Default what oil to use when running in?
im wondering the best oil to use when running in my zetec turbo as ive heard several different opinions, should it be mineral, semi symphetic etc?
Old Apr 7, 2008 | 06:15 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
have u had a rebuild or just taking it easy........................after a build use a mineral oil that is recomended for the engine..(manufacturers hand book)...ie 10/40........10/50 etc
Old Apr 7, 2008 | 06:53 PM
GARETH T's Avatar
GARETH T
mineral all the way!
and dont take it too easy when running a car in,, you need pressure on the ring lands for them to force themselfs onto the chamber walls!
Old Apr 7, 2008 | 06:54 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Cars all running then?
Old Apr 7, 2008 | 06:56 PM
Billabong's Avatar
Billabong
It does make me laugh when people often say 'use the cheapest crap-iest oil you can find.'
Old Apr 7, 2008 | 07:29 PM
Stu.H's Avatar
Stu.H
After Karl built my engine, I used mineral for about 1000, then semi for about 1000, and now just put Mobil 1 15/50 in it.
As said, dont be too shy on the loud pedal either, but that doesnt mean redlining it either
Old Apr 7, 2008 | 07:37 PM
rst in breaking
ive been speaking with ian howell and he's recommended me on how to run it in, im hoping if all bits arrive and all goes well and i get the other car out the garage and mine in i can have it in wednesday and running by friday (with no xhaust) lol, im going to make the engine loom up and leave it long the re-do it when all the extras are on the management and running so nothing is missed , going to try for central day now, absolutely gutted i wont be able to show it though, anyone pulling out who has a ticket for sale?
Old Apr 7, 2008 | 07:50 PM
biglee's Avatar
biglee
Audio specialist
the only person you should see about running-in is your engine builder he will tell you what you should be doing,
i use millers running-in oil, yes they do a specialised oil for that very job... i will do 400 miles ish and cycle between 3K and 4K alot and also not be to gentle with it... try and get to allsorts of loads, up hills ..over run ect.. thats how i do it and never had an issue whatsoever.
good luck.
Old Apr 7, 2008 | 10:02 PM
rst in breaking
cheers guys, hopefully with the engine loom etc in she'll start
mk22door
49
Mar 26, 2022 07:15 AM
Chas
Sep 21, 2015 08:57 PM
StephTell
Sep 2, 2015 06:31 PM
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
