Blocked breather S2RS!!!
Old Oct 22, 2004 | 03:17 PM
Hartyboy's Avatar
Hartyboy
Default Blocked breather S2RS!!!
Whats the best way to unblock the breather pipes and will it cause bad running if theyre blocked???
Old Oct 22, 2004 | 03:38 PM
Jim Galbally's Avatar
Jim Galbally
as above
Old Oct 22, 2004 | 03:39 PM
sm's Avatar
sm
they do cause a bit of bad running mainly lumpy idle i think, best way is to take em all off and blow through them with a compressed air line should clear it all out and replace the breather filter, there only about 3 quid from a motor factors, got to do mine this weekend if it dont rain
Old Oct 22, 2004 | 03:43 PM
Paddy's Avatar
Paddy
Legend
yeah, it'll run lumpy on idle maybe even keep cutting out [on idle].
Old Oct 22, 2004 | 04:43 PM
Hartyboy's Avatar
Hartyboy
Is the breather filter the 1 way valve bit like a cone shape thing???
Old Oct 22, 2004 | 04:51 PM
sm's Avatar
sm
yep thats it
Old Oct 22, 2004 | 05:04 PM
James Raby's Avatar
James Raby
High pressure water hose etc??
That's what I done mine with...
Old Oct 22, 2004 | 05:13 PM
Hartyboy's Avatar
Hartyboy
i'll be doing that monday then cheers mate
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
