cosworth cambelt
Old Apr 6, 2008 | 08:21 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default cosworth cambelt
hi
can anyone tell me if its possible to change a 2wd cosworth cambelt without removing the bottom pulley
cheers
mark
Old Apr 6, 2008 | 09:20 PM
mechanic28's Avatar
mechanic28
no fella yours abit stuck?take it i mean the aux pulley for the alt and power steering belts
Old Apr 6, 2008 | 09:34 PM
MARKYMARKONE
i have'nt tried to take my pulley off yet, i only asked as i heard the cambelt could be slipped down the back off the pulley without to much hassel.
also is therre any difference between the 2wd and 4x4 aux/bottom pulley or are they interchangable
many thanks
mark
Old Apr 6, 2008 | 09:36 PM
mechanic28's Avatar
mechanic28
not that i am aware u can get the belt off with pulley still in place unless it been modified!not sure bout the pulleys soz fella!
Old Apr 6, 2008 | 09:41 PM
Twellsie's Avatar
Twellsie
the pullieys vary from model to model
Old Apr 6, 2008 | 10:03 PM
MARKYMARKONE
thanks for the replys guys will have too take a look
Old Apr 7, 2008 | 06:14 AM
You CAN get the belt done with the pulley still IN PLACE.
It is done by bending the large dishes washer between the belt and the pulley.
As said pulleys vary as some are serpentine, some V belt.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
