3 Door ABS
Hi
Does anyone know where i can get the tiny rubber seals located in the ABS unit of a three door (they are the ones which fall out when you disconnect the bracket & wont go back in)
Also does anyone know where or who supplys the exact spec brake lines which pass accross the bulkhead between the servo unit & the ABS unit?
ANy help is greatly appreciated.........
