sapph interior
Old Apr 6, 2008 | 06:35 PM
fezzajsy's Avatar
fezzajsy
Default sapph interior
just looked at my sapph and notice the roof lining is a little sagged.does any one know how to repair this?
thanx
Old Apr 6, 2008 | 06:42 PM
I have used carpet spray glue. Its called superspray adhesive and its made by a company called stikatak its in a blue and pink tin. I did mine about 8 months ago and to be honest it needs doing again.
Old Apr 6, 2008 | 07:59 PM
iansoutham's Avatar
iansoutham
OCD Victim
The velour rooflinings on the later models have an inherent fault of "drooping".
This is because there is a thin layer of foam between the velour material and the cardboard backing. If you try to do anything with this foam in place, you will have to redo it @ a later date as the foam disintegrates with age.
What I do is to remove the rooflining completely through the boot, gently pull back half the covering (normally to the middle of the sunroof aperture, brush any foam off and then apply the spray adhesive, let it set for a couple of minutes until it is tacky, then gently roll the velour back into place using a plastic card or similar. This prevents any wrinkles or over-stretching of the material.
Leave it overnight, then refit to the car.
Old Apr 7, 2008 | 06:03 AM
I used HALSTEAD, carpet glue, this is what I used to use to stick CARPET it self on the roof underside in trucks(converted horseboxes) always held firm, even with 1/2" thick carpets, 10 feet square.
Old Apr 7, 2008 | 03:02 PM
fezzajsy's Avatar
fezzajsy
cheeRS guys
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stevecfrst1
Sep 30, 2015 05:18 AM
DavidK
Sep 27, 2015 02:55 PM
