Where can you get Black Polybushes?
Apr 5, 2008 | 06:48 PM
I'm sure I've seen someone selling these?
Apr 5, 2008 | 07:47 PM
Apr 5, 2008 | 08:23 PM
Do power flex not do them as a special order?
Apr 5, 2008 | 08:28 PM
I'm sure I get them made in black Paul if your interested I'll double check and let you know on monday.
Apr 5, 2008 | 09:00 PM
Cheers Dan
I need the rear outer trailing arm bushes and the big rear beam mounts
Can you still get the Group-N jobbies?
Apr 5, 2008 | 09:08 PM
Quote:
Originally Posted by
Paul Ripley
Cheers Dan
I'll find out about the grpn ones but I think that trailing arm one is still available from for so would use that TBH I know one is NLA though
I can get the Big Beam ones done in a harder material if you want.
Any chance of a Fini code for the plastic screws on the inside sill and the black rivits things on the side of the lower panel?
Apr 5, 2008 | 10:19 PM
Can get the finis mate but not sure what you exactly after from the description
Apr 5, 2008 | 10:39 PM
so colours determine how the bushes perform?
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
