Viscous Coupling 4x4 Cosworth
Old Apr 3, 2008 | 05:26 PM
jpbaginski's Avatar
jpbaginski
Exclamation Viscous Coupling 4x4 Cosworth
Viscous Coupling on a 4x4 cosworth is worn, is it bad to drive fast with a worn one!
I know that this sounds stupid but how much damage can be done.
I know that this controls the torque power to the front and rear wheels, and if worn l've been told transfers more to the rears, so should this be done as soon as possible?
My mate says that the drive feels no different even though he was told that his coupling was worn.
Thanks.
Old Apr 3, 2008 | 05:29 PM
2ndGear's Avatar
2ndGear
i had one go in my cosworth it was like driving a 2wd car! They can be beefed up and take more power this is done by improving the plates that are internally to the viscous coupling. Depending on were you are located i will pm you the details of were i got mine done.
Old Apr 3, 2008 | 05:42 PM
jpbaginski's Avatar
jpbaginski
Yes that would be great I am in the Bath area.
Old Apr 3, 2008 | 05:52 PM
babscossie's Avatar
babscossie
how do you tell is its worn
Old Apr 3, 2008 | 06:00 PM
jpbaginski's Avatar
jpbaginski
Rolling road will tell you!
Old Apr 3, 2008 | 06:02 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
marco can do uprated vc's in various stages....
Old Apr 3, 2008 | 06:04 PM
col cos1's Avatar
col cos1
not bad to drive it when worn unless you cant go sideways...lol
Old Apr 3, 2008 | 06:25 PM
Azrael's Avatar
Azrael
They handle like shite on the limit, apart from that you'll be fine Basicallyyou have open centre diff.
Old Apr 3, 2008 | 06:30 PM
jpbaginski's Avatar
jpbaginski
Won't do any damage to drivetrain or gearbox then?
Old Apr 3, 2008 | 06:33 PM
Azrael's Avatar
Azrael
If the VC is leaking it's silicone fluid it's not very good for the condiiton of the oilk in transfer case but it shouldn't do much damage as there is only marginal volume of it anyway. Apart from being poor car to drive on the limit everything else should be fine. It isn't a big job on a Cossie htough so why not fix it?
Old Apr 5, 2008 | 10:43 AM
marco polo's Avatar
marco polo
Hi Mate
can get your center Vc re done or can part exchange yours
60Nm is enough for raod/track/tarmac and more it will push on a bit
gravel different story
Old Apr 5, 2008 | 12:32 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
If you want one off marco, I can drop it off for you as I only work 20 mins from bath?
Chas
Sep 21, 2015 08:57 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
