AP's
Old Apr 3, 2008 | 02:49 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Default AP's
Can any AP's fit under standard S1 wheels or would I need to take the bigger rims route ? I doubt any will, but just thought I'd ask.........
Old Apr 3, 2008 | 03:10 PM
charlie luciano's Avatar
charlie luciano
I would say you need bigger rims bruv as most AP calipers are on the large side.
I had the old austin princess old skool 4 pot set up on my Granada ghia x and they fitted under 15's, wasn't bad either
Luciano
Old Apr 3, 2008 | 03:29 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need to be asking the likes of matrin and nuts rs sort of guys who specificly deal with brake kits for a difinative answer
assuming you are going to be using the nriginal 15's i don't think you'll get away with them, but i have seen a set of ap's bolted behind a late 92 cossie spec rim (the bbs style one) on 300's so it's possible
Old Apr 3, 2008 | 03:44 PM
NUTS RuS's Avatar
NUTS RuS
Short answer is Yes
Old Apr 3, 2008 | 03:46 PM
bud-weis's Avatar
bud-weis
Football Cwazy
I'm sure you can get calipers small enough, and good enough to suit your needs...will be dear though i guess.
Lots of race cars run small wheels with AP brakes.
Jasesapphy's Avatar
Jasesapphy
we run compbrake 4 pots and 285mm brakes under 15s
Old Apr 3, 2008 | 03:52 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Royalty now are "we" .
Old Apr 3, 2008 | 04:20 PM
rsjp's Avatar
rsjp
got these under some 15 inch brooklands capri wheels on a series 1 turbo
proper stoppers
jp
Old Apr 3, 2008 | 04:21 PM
Jasesapphy's Avatar
Jasesapphy
Dont start Rainbum , we as in Me and Ratty on the Goon Track Car
Do you supply parts for that then
Old Apr 3, 2008 | 04:23 PM
Mr S1's Avatar
Mr S1
proper stoppers
jp
Oooh !!! OK, what size etc are they, would they fit under S1 rims and most importantly - how much ?!
Old Apr 3, 2008 | 04:32 PM
series1rscars's Avatar
series1rscars
AP's are porn
Old Apr 3, 2008 | 04:46 PM
NUTS RuS's Avatar
NUTS RuS
Originally Posted by series1rscars
AP's are porn
Just for you then
Those are similar to the ones we designed the brackets for to fit under some 15" wheels
