fan switch
Old Apr 2, 2008 | 04:22 PM
k300rs's Avatar
k300rs
Default fan switch
can anyone tell me which terninals you bridge to see if your fan switch is broke as there is 4 and my fans are not kicking in?
Old Apr 2, 2008 | 04:40 PM
Rippers's Avatar
Rippers
Monte Geek
Ideal opportunity to go 2wd
http://www.escortrscosworth.com/view...php?f=14&t=506
Old Apr 2, 2008 | 05:05 PM
k300rs's Avatar
k300rs
tried to connect the live to the neg when un plugged to crate circuit heard a relay clicking but no fans. what should i try now?
thanks for any help nats
Old Apr 2, 2008 | 08:53 PM
stookay's Avatar
stookay
ive had a similar problem , fans were jammed on , changed fan switch , now they never come on , but if i bridge multi plug with loop of wire , i can get the low speed and high speed fans to come on . i just gave up trying to sort it .
Old Apr 3, 2008 | 07:04 AM
bpspa's Avatar
bpspa
have you tested the relay to make sure you are getting at least 12 volts on the fan circuit
Old Apr 3, 2008 | 03:44 PM
Dave Henshall's Avatar
Dave Henshall
the 4 wires that go to the switch, if you connect the 2 blacks together and the 2 black with blue stripes together, then the 2 new pairs together (effectively shorting all 4 together) the fans should come onto hight speed, if not, possibly the large unsidedown green relay that clips onto the side of plastic partition next to the battery , the relay is about 35 quid IIRC...
Old Apr 3, 2008 | 04:24 PM
k300rs's Avatar
k300rs
what do i do to test the relay as i can hear that clicking but no fans? Hard wired them today and worked fine.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
