2wd exhaust manifold on a 4x4
Old Apr 2, 2008 | 12:13 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Default 2wd exhaust manifold on a 4x4
Hi all, ive got hold a 2wd exhaust manifold and want fit it to my 4x4 saph.
Apart from turning the housings around on the turbo and fitting a turbo damper, is there anything else that needs to be done?
Cheers,
Gary.
Old Apr 2, 2008 | 06:37 AM
I beleive there is roughly 2" difference in exhaust downpipe height, but can't remember which way it is.
Old Apr 2, 2008 | 07:22 AM
paulfreeman's Avatar
paulfreeman
Wink
4x4 manifolds are more compact and hold the turbo lower so the centre of gravity. if you want a BIG power motor the 2wd manifold is a better flowing manifold but we are talking 400BHP Plus, which face it your never going to have.
Old Apr 2, 2008 | 08:54 AM
IANS2RST's Avatar
IANS2RST
exhaust downpipe will need modding. you need to chop about 2 inch out from just behind the turbo flange & add it into the downpipe.
ask martin at reyland he knows how to do it
turbo damper is not a bad idea either to help support the extra weight.
also you will need a 2wd heatshield as the 4x4 one won't fit with a 2wd manifold.
it does sacrifice some low down torque but it does pull harder on the top end. if yours is a road car I would stick wit the 4wd manifold. if its used for fun & on track then do it.
Old Apr 2, 2008 | 12:30 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Oooh! Bitchy!!! Well, at least WHEN i get over 400BHP, I will be able to put the majority of the power down on the road unlike you my front wheel drive friend!!
Until the gearbox breaks that is!!
Cheers for the advice everyone, i wont bother until the bottom ends been rebuilt i think. I want a new exhaust anyway as i hate the one ive got now!
cheers
Gary.
Old Apr 2, 2008 | 12:53 PM
IANS2RST's Avatar
IANS2RST
stat saving for a gearbox, I'm on my 3rd with over 400bhp!!
current one isn't doing too bad, think its a dome one with shootpeened gearset etc
Old Apr 2, 2008 | 06:13 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I will get a box built but for the meantime i'm just gonna have to take it easy.
Mind you that'll be a challenge! Everytime i say i'll take it easy, it just goes out of the window and i end up busting it again!! Lol!
How much was your gearbox and what is it ie; straight cut, big tooth etc?
May 31, 2016 09:28 PM
mint_s2
Sep 2, 2015 08:58 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Old ford
Jul 31, 2015 06:50 AM
