205 block
Old Apr 1, 2008 | 06:09 PM
ellicoss's Avatar
ellicoss
Default 205 block
right was wondering if a pinto 205 block the same as a cossie 205 block as i have been offerd 1 and im not sure
Old Apr 1, 2008 | 06:27 PM
BigErn's Avatar
BigErn
Yip, you just need it machined to take the pistons iirc. Make sure you get the crank bearing caps with it though.
Old Apr 1, 2008 | 06:34 PM
ellicoss's Avatar
ellicoss
So there a smaller bore standard are they so if its warn i can still get it machined to standard bore
Old Apr 2, 2008 | 06:58 AM
They are the same block and the cossie ones were just selected as being the closest ones which had the best bore sizes straight off the production line.
Old Apr 2, 2008 | 09:39 PM
costina's Avatar
costina
Live long and prosper!!
Which is all 2222 marked by the dizzy hole
paul
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
