Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
mk6 rs 2000 hunting
Old Mar 30, 2008 | 07:32 PM
webby80's Avatar
webby80
Question mk6 rs 2000 hunting
also looked at a few that when first fired up hunt a bit till you drive them is this a normal problem sorry for my ignorance but im a cvh boy lol
Old Mar 31, 2008 | 08:00 AM
stuey650's Avatar
stuey650
it is hunting wildly (nearly stalling) perhaps spluttering at low revs when driving then its most likely the Idle speed control valve at fault. These can be cleaned up, failing that a new one from fords is about Ł90. Quite a common fault on these cars. Bad coil pack wiring, coil packs can also cause this. If its just a mild hunt at idle i wouldn't worry about it to much. Mine occasionally does this from time to time for no particular reason.
Old Mar 31, 2008 | 05:22 PM
webby80's Avatar
webby80
yer its only a mild hunt , thanks mate
Old Mar 31, 2008 | 08:45 PM
nickscunny's Avatar
nickscunny
check the rear chassis legs and check the wishbones.....
Old Apr 2, 2008 | 10:01 PM
webby80's Avatar
webby80
yer looked at a right basket case the other day that was like that
Old Apr 3, 2008 | 07:11 AM
martysport's Avatar
martysport
Mine was dead smooth, untill I changd the cams
Old Apr 3, 2008 | 05:28 PM
Icurus's Avatar
Icurus
Rough idle can also be attributed to an air leak on the inlet system. A quick test is to un-plug the ISCV's electrical plug, the engine should stall right away, if it chugs on then you have an air leak
gambo08
Feb 4, 2016 10:49 PM
little bram
Sep 27, 2015 07:45 AM
