Cam shalf seals (replacing)
Old Mar 30, 2008 | 05:53 PM
lamb chops's Avatar
lamb chops
Default Cam shalf seals (replacing)
Took my car out for a good spin today first time all winter and when i got back noticed oil runing down the block, on closer inspection it looks lik one of the cam shaft seals is weaping.
How easy are these to change? in the book it says remove the ball race.. do you need to do this as its looks complex..
Old Mar 30, 2008 | 06:45 PM
NO need to remove bearing.
Just take belt/pulley off, lever old one out, install new one.
Use a VITON one if you don't want the leak back, they are about £9 each, might as well do both whilst there.
The seal size is 35-47-7.
Old Mar 30, 2008 | 06:58 PM
lamb chops's Avatar
lamb chops
Thanks Tabs, allways to the rescue
Old Apr 5, 2008 | 09:47 PM
Bubs's Avatar
Bubs
T/belt off, pulley off, lever it out and tap the new one in. use the old one when tapping it in so you dont damage the new one or you can buy special tools for refitting cam seals i just use the old ones.
Old Apr 6, 2008 | 03:25 PM
PAUL S's Avatar
PAUL S
John
you may well find that replacing them wont cure the leak, had this a couple of times now and its usually always the half moon seals, these drip onto the cams and it looks as if its coming from the cam seals - they are your next port of call.
Old Apr 6, 2008 | 05:38 PM
lamb chops's Avatar
lamb chops
Your right!! It didnt cure the leak.. It could be the half moons I guess but ive replaced them allready when i refitted the rocker.. I even sealed them with some gasket sealer.. The only other thing is the cam bearing seal i guess..
Old Apr 7, 2008 | 06:17 AM
The one area most forget is the CAM CAP, they leak between the join of that and the head, and of course it is exposed at the front either side of the cam pulley.
Old Apr 7, 2008 | 01:09 PM
lamb chops's Avatar
lamb chops
is this the little allen screw Tabs? I need to check that..
Old Apr 7, 2008 | 05:35 PM
NO, the cap that holds the bearings at the front of the cams, the r/c goes onto this at the front, BUT the join between the cap/s and the head can leak, so always use a LITTLE sealer here.
Old Apr 7, 2008 | 05:40 PM
lamb chops's Avatar
lamb chops
ok so remove the pulley again and then the small bolt and remove the cap, clean, sealer, refit? I will give this a go. Theres one at the top and bottom isnt there from memory?
Cheers!!
Old Apr 8, 2008 | 10:40 PM
lamb chops's Avatar
lamb chops
do you mean the bolts with the small plates holding the bearings in this pic Tabs
Old Apr 8, 2008 | 11:07 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Here you go
Pink circles show where Tabetha means. Green lines is where you should put a small amount of sealer as well as the usual drop on the end of half moons.
Old Apr 9, 2008 | 06:28 AM
Thanks RICHIE, dead right, I just can't do piccies, only just got past the on/off switch on the compy!!
thanks,
Old Apr 9, 2008 | 08:39 AM
lamb chops's Avatar
lamb chops
ah right thanks Rich... TBH i thought that bit was part of the head
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
cos elle
Sep 25, 2015 09:52 AM
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
hopper350
Sep 4, 2015 12:53 AM
