Best way to check for warped discs?
Old Mar 30, 2008 | 05:33 PM
S2Steve's Avatar
S2Steve
Default Best way to check for warped discs?
I get a lot of vibration under breaking, so I'm assuming my discs are warped, is there a way to double check my prediction without the use of a gauge or specific tools?
Old Mar 30, 2008 | 06:46 PM
Easy, jack up car and spin wheel, you will feel and see it stop on any tight(warped) spot.
Old Mar 30, 2008 | 08:00 PM
S2Steve's Avatar
S2Steve
I can see a S2 rolling off a jack down my driveway by doing that!
Old Mar 30, 2008 | 08:04 PM
JamesH's Avatar
JamesH
Why?
He means spin the wheel that is off the ground, and you will see resistance (possibly warped spot of the disc)
Old Mar 30, 2008 | 08:07 PM
S2Steve's Avatar
S2Steve
Ok maybe i'm being stupid but it wont spin with the handbrake on?
Old Mar 31, 2008 | 11:20 AM
sortedsaff's Avatar
sortedsaff
will spin with the handbreak on bud
Old Mar 31, 2008 | 12:16 PM
S2Steve's Avatar
S2Steve
Haha, oops.
Old Mar 31, 2008 | 04:41 PM
You had me thinking it was a citroen then with handbrake on front wheels!!
Old Mar 31, 2008 | 05:37 PM
S2Steve's Avatar
S2Steve
Sorry i'm used to driving a rwd capri, and that was on the front, I just assumed (for some odd reason) that the handbrake worked on the wheels that didn't drive the vehicle. Dumb!
Old Apr 1, 2008 | 05:46 AM
NO, 99% of handbrakes on the rear, as with CAPRI's, of all ages, defo on the rear.
With rear discs some are internal, inside the drum part of the disc, some(most) external mechanical on disc like normal caliper.
Citroen's way more advanced than fords, and pretty much all others, of thie time, so that is why they were different.
Old Apr 1, 2008 | 06:39 AM
dojj's Avatar
dojj
Resident Wrestling Legend
some saabs have the handbrake on the front wheels too
if its not the discs it can also be a bush or a ball joint out
Old Apr 1, 2008 | 05:15 PM
Hey dojj,
I have two ferraris for you so far, a F50 and Enzo, should be three by now but they ran out so kept my receipt, will send when I got the lot.
Old Apr 9, 2008 | 06:15 PM
S2Steve's Avatar
S2Steve
Got my new set of 283 cossie discs today, put em straight on and the juddering has stopped. Woo!
Old Apr 10, 2008 | 06:16 AM
For NOW at least!!
Old Apr 10, 2008 | 06:46 AM
dojj's Avatar
dojj
Originally Posted by tabetha
Hey dojj,
they seem to only have the superamerica and either the 430 tin top or the 430 hard top left now
i suppose the others are more popular
Old Apr 10, 2008 | 03:16 PM
They were run out again so again I kept the receipt, so will get them eventually!!
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
dojj
Sep 29, 2015 10:32 PM
SMILER258
Sep 28, 2015 09:04 AM
