View Poll Results: which suspension
bilstein
60.00%
koni adjustables
40.00%
Voters: 10. You may not vote on this poll
escos suspension
Old Oct 21, 2004 | 07:58 PM
steviecossie's Avatar
steviecossie
Default escos suspension
which suspension for my escort cossie
i need some help from you lot. i have priced
all of these kits and they are all round about the
same price which should i go for:
bilstein;
koni adjustable;
gaz coilovers;
give me your vote folks.
Old Oct 21, 2004 | 07:59 PM
mattbibs's Avatar
mattbibs
gaz coilovers isnt in the poll!
Old Oct 21, 2004 | 08:08 PM
steviecossie
there is a new poll lads i cocked this one up
SORRY!
Old Oct 21, 2004 | 08:12 PM
bbigman2000's Avatar
bbigman2000
had konis all round on my esco and lowered 25mm adjustable, pretty good set up in my view, obviously some proflex jumbo's be better but there pricey
bb
Old Oct 21, 2004 | 09:53 PM
GARETH T's Avatar
GARETH T
what do you do with the car?
Old Oct 21, 2004 | 10:02 PM
Phil's Avatar
Phil
Jeebus
Mike Rainbird runs Koni's on his car and the handling is simply awesome even on track
Old Oct 21, 2004 | 10:04 PM
I run koni's on the front with lower springs fully adjustable damper and i run bilstiens coil ovvers on the back.The back coil overs are terrible ride but the fronts are great id say the konis.
Old Oct 22, 2004 | 02:42 AM
Kelv's Avatar
Kelv
Almost there!
i used to run my old escort on koni adjustables with chassis dynamic springs and it was fully polybushed, couldnt really fault the setup to be honest!
New escort has spherical bearing top mounts, gaz coilovers, adjustable track control arms and compression struts to do away with the front anti roll bar, every bush that still existed has been changed for a poly item, havent had chance to try it on the road yet but im hoping it handles spot on... even if it does give a bit of a harsh ride!!!
Old Oct 22, 2004 | 05:12 AM
dave cos4x4's Avatar
dave cos4x4
Got Gaz coilovers on my car and they handle spot on compared to the koni's.
Abit harsh but i have not tried to ajust them yet to a softer setting.
Dave.
Old Oct 22, 2004 | 06:45 AM
Paul Eggleton's Avatar
Paul Eggleton
I'm currently running adj tca's, and a rosejointed zoo beam on Avo coilovers. Short of spending on mega stuff it's the absolute bollocks
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
