fitting koni's on a 2wd
bought some konis the other day shocks and springs for my 2wd saph...can anyone give me some instructions on how to fit them in...il give it a butchers if the weather is good tomorrow!
cheers
raz
cheers
raz
Piss easy mate...
Undo bolt that connects hub to bottom of shock, undo nut on top of strut in engine bay.
Smack the hub of the shock, take out, new one in, do bolts back up DONE
Tab had the great idea of putting the bolt in back to front to force the clamping on the hub apart - putting a washer in to wedge against. I'd disconnect the anti roll bar at the bush under the floor and lever it all down with a long bar and minimum of hammering myself. Did it this way yesterday and it all worked apart easily. Disconnecting the steering joint on the side you are doing also gives you more access if you need it.
Oct 9, 2015 07:38 PM
markk
18
Aug 17, 2015 05:19 AM
155lee
Aug 14, 2015 11:21 AM
lockie
Jul 31, 2015 10:03 PM
