Help with suspention
Hi what sort of suspension do u use on your escos? I have gaz dampers but not sure what springs. The car sits very low maybe to low,it is very bumpy and i've had enongh of it. It makes driving the car a chore.The car is used mainly on the road occassionly on the track .Just wondering what u all use ? p.s please help as missus is moaning too!
KELV. No there not coilovers mate but they are quite new do u reckon its worth changing
the springs then and if so what would u recommend .
MIKE DAF2. I have konis on my saff which rides really nice but i do not know what springs they are as they were on the car when i bought it .What springs are u using?
THANKS
THANKS
Cozzieq, not sure what the springs are as they come as a complete kit. i have also tried the koni web site to see if they list the spring rates but they don't. I would try standard springs with koni shocks if you dont want to lower it as this will still give you a comfortable ride still
MY suggestion would be to speak to Mike Rainbird.
A set of New Koni's and Ahmed Bayjoo Spec Springs
http://www.randbmotorsport.co.uk/
