Front Heated Screen Problems
Old Mar 28, 2008 | 11:05 PM
KSA-Cossie's Avatar
KSA-Cossie
Do you have a negative at switch dave ?
Old Mar 28, 2008 | 11:15 PM
KSA-Cossie's Avatar
KSA-Cossie
I used the wiring diagrams in the haynes manual for my saph don't know if the wiring is the same on the escos though.
Old Mar 29, 2008 | 04:45 PM
My live for the FRONT one disappeared so jumped it from the rear one.
You need to check the output from the battery all the way through to the ignition switch then to switches, but break could be anywhere.
Old Apr 1, 2008 | 05:36 AM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Dont know if you got it or not Dave but i did reply to your PM over a week ago
Old Apr 1, 2008 | 06:37 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if the esco one is anything like the other ford set ups then the screen wiring will be independant to the rest of the loom
but you need it connected to the ecu as it only comes on when the engine is running
so if you haven't turned it on it won't work on just the ignition on setting
3i Jim
Nov 20, 2015 05:12 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
