rear caliper slider pins 2wd ?
Old Mar 28, 2008 | 08:06 PM
Tim's Avatar
Tim
Default rear caliper slider pins 2wd ?
can you get the slider pins for the rear calipers? the ones from carrier to caliper ? mine have worn flats on the sides can this cause the caliper to stick on etc?
tim
Old Mar 29, 2008 | 11:50 AM
Moonstone Mart's Avatar
Moonstone Mart
I think they are supposed to have flats on the sides mate
Mart.
Old Mar 29, 2008 | 01:44 PM
IANS2RST's Avatar
IANS2RST
think you can still get these from ford m8, if not just go looking for granadas & scorpios-all the ones with solid discs use the same calipers/carriers as the 2wd cos
Old Mar 29, 2008 | 04:17 PM
As said mine have flats, as std.
FlashRS
Sep 14, 2015 12:36 PM
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
james kiely
Aug 28, 2015 08:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
