Head work
Old Mar 27, 2008 | 01:52 PM
Zetecfiesta's Avatar
Zetecfiesta
Default Head work
Hello people, the head on my 1988 rsturbo is getting a little tapperty and its starting to do my tree in, as the car is only lightly modified with the usual, chip, exhaust, airfilter and front mount the next logical area is the head!
so what should i go for? a stage 1 2 or 3? i dont really get what the different stages are so any explination would be great, and what comes with the different stages
again goes for the cams there are loads on market and then there are all the different models within each brand but what would be best for the engine ive got?
i dont mind rebuilding it myself as ive got all the tools i just need to get all the different parts together any other advice would be great!
Old Mar 27, 2008 | 02:05 PM
sortedsaff's Avatar
sortedsaff
also be interested in this too . as my head is supposed to be a stage 2 and dont realy know what im looking for to see if it is .
Old Mar 27, 2008 | 02:13 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
stage 1 standard valves ported
stage 2 bigger inlet valves standard exhaust valves ported
stage 3 bigger inlet valves and bigger exhaust valves ported
NMS do good ported heads but there is a long waiting list > http://www.norrismotorsport.co.uk/index2.html
Also pumaracing is very good but yet again a long wait > http://www.pumaracing.co.uk/
Jamsport also do good heads and they usually have them in stock > http://www.jam-sport.co.uk/
Old Mar 27, 2008 | 02:57 PM
Zetecfiesta
so if i chucked on a stage 3 head id obviously be drawing in more air and getting rid of it quicker but would that then mean id need to uprate the turbo as well?
Old Mar 27, 2008 | 03:12 PM
G2RSR's Avatar
G2RSR
Bodybuilding
no you can use it with the standard turbo you will have more power at the same boost pressure from the improved VE
Old Mar 27, 2008 | 03:16 PM
G2RSR's Avatar
G2RSR
Bodybuilding
Nick from PF was running Jamsport head piper 285t2 cam pro alloy front mount and standard turbo 18 psi 250 bhp iirc
Old Mar 27, 2008 | 03:21 PM
Zetecfiesta
quality, right lets find some prices lol!
obviously it will need mapping as well wont it, anything else i should uprate/update whilst im doing that?
Old Mar 27, 2008 | 03:31 PM
G2RSR's Avatar
G2RSR
Bodybuilding
i think NMS are about Ł500
Pumaracing Ł650
Jamsport about Ł400
not much more you can do yourself next after the head and cam would be a bigger turbo something like a stage 2 hybrid 5th injector or a change to Efi management
Old Mar 27, 2008 | 04:15 PM
Stage 1/2/3 different from different people, as thier view is different on what the stages are.
You could try DARREN at DAMICO, 01953 717784.
He is awsome with heads as that is all he has ever done, has flow rigs, engine dyno's etc , so unlike some his heads are not guesses.
Old Mar 29, 2008 | 09:23 PM
Zetecfiesta
im currently collecting efi parts as i go, slowly and cheaply!
Old Mar 29, 2008 | 09:37 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
i have a ported head if any 1 want it Ł75ono
will suply with
valves
spings
retainers
new valve stem oil seals
Old Mar 29, 2008 | 09:42 PM
craig rs's Avatar
craig rs
if anyone wants there head porting/ polishing i can do it for u, i do them on a daily basis for the company i work for, i`ll do it for Ł100 all in, can do other head work aswell, just pm me
Old Mar 29, 2008 | 10:02 PM
jonnyrsturbo
you have a pm mate!
Old Mar 29, 2008 | 11:40 PM
G2RSR's Avatar
G2RSR
Bodybuilding
fpmsl at diy ported heads
Old Mar 30, 2008 | 09:55 AM
ROB7656's Avatar
ROB7656
if you had standard cam 7psi and a stage 1 head what kind of power increase would you expect obviously there would be less lag etc 5bhp???? i am still running origional cam at 120k should imagine its pretty worn so may replace the head.
cheers
Old Mar 30, 2008 | 11:36 AM
Zetecfiesta
thanks for all the replys people, looking at so many different options now lol!
EFI wise ive allready got the inlet, injectors and throttlebody. along with the map sensor and coilpack and ht leads.
got a price from cylinder head developments which seems quite reasonable and ive allways heard great things about the owner.
need to look at cams now, any recomendations, kent, piper, newman?
Old Mar 30, 2008 | 12:53 PM
jonnyrsturbo
piper bp 285 t2 in mine
good stuff
Old Mar 30, 2008 | 05:11 PM
craig rs's Avatar
craig rs
m8 theres nothing diy about me porting a head, i work for a company called autocraft, basically speciallising in performance cylinder heads, about as far from diy as u can get
Old Mar 30, 2008 | 05:28 PM
jonnyrsturbo
are you wantin this cylinder head?
Old Mar 30, 2008 | 08:58 PM
boothy's Avatar
boothy
wot sort of stage could u do this too mate.
Old Mar 30, 2008 | 09:01 PM
boothy's Avatar
boothy
Default head
wot sort of stage could you do this to mate would you deffo feel a difference???
how far away areyou from manchester mate could be interested cheers mate rob
Old Mar 30, 2008 | 10:05 PM
Zetecfiesta
ive just bought an efi engine lol! gonna build the engine over the summer and fit it at xmas time! need something to keep me ocupied lol.
3i Jim
Nov 20, 2015 05:12 AM
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
salsheikh
Jul 30, 2015 08:45 PM
