Sapphire Cosworth 4x4 T3
Old Mar 27, 2008 | 07:01 AM
NAKRS's Avatar
NAKRS
Smile Sapphire Cosworth 4x4 T3
Hi Does Anyone Know Whats The Maximum Boost You Can Run On A T3 Turbo Before It Blows Up
Currently Running A Stg3 Pts Chip -31 3bar Greens 044 Pump
Ive Had It On 1.5 Bar Already...
Old Mar 27, 2008 | 07:22 AM
KSA-Cossie's Avatar
KSA-Cossie
Ran 26 psi on my old one before i fitted my t34.
Old Mar 27, 2008 | 04:23 PM
It won't actually blow up just severely shorten it's life.
It is only a basic air pump, so will only give out a certain amount of puff, when the boost goes no higher it is at it's limit.
I have heard of 26/29psi, but life will be severly short at this pressure.
Old Mar 27, 2008 | 04:27 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
You can see 2 bar lower in the rev range, but its not capable of maintaining it higher up.
Old Mar 28, 2008 | 07:45 PM
RS craig 71's Avatar
RS craig 71
my saff runs hybrid stage 1 T3 it peaks at 26psi and holds 23psi courtesy of MSD.
SmudgerByName
52
Jul 28, 2016 06:14 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
lukeeboy149
Aug 22, 2015 04:29 PM
cossie4x4
Aug 14, 2015 06:29 PM
yawiejon
Aug 10, 2015 08:12 PM
