rs 1800 alarm
i have two alarms on my rs 1800, one is a toad witch i would like to keep on the car, the other is the ford one that comes on when you lock the car with the key, is there any way to remove this as i would like to delock the doors and dont want a prob later on with this alarm
thanks lee
thanks lee
Just delock as normal, just amke sure you leave the motor etc there connected and it will be no problem.
My old mondy used both FORD alarm and TOAD, it was useful if I needed to leave the toad in service mode could still lock and alarm with ford(key) one.
