saph sideskirts, clips snapping - workarounds?
Old Oct 21, 2004 | 01:46 PM
Jim Galbally's Avatar
Jim Galbally
Default saph sideskirts, clips snapping - workarounds?
ok those crappy clips that clip up to the sill bit at the bottom that ALWAYS snap... does anyone have any secret methods for avoiding this?
one i head was to drill a small hole thru the sil bit and the broken clip and cabletie it together...
any other methods anyone's using?
i'm sick of spending a LOT of money for some stupid crappy clips that snap the moment you put them on ALL THE TIME theyre not cheap! especially when you have to buy each one 3 times coz they all break when fitting
Old Oct 21, 2004 | 01:47 PM
CraigN's Avatar
CraigN
im getting new ones jut have to drill the rivets off and re rivet them they are 15 years old or so jim
Old Oct 21, 2004 | 01:49 PM
Jim Galbally
craig, thats the THEORY... lol
you wait till you try and clip it onto the sill....
push push push push SNAP!
CraigN: "AAARGH!!! FUCKING CRAPPY SLIP MOTHERFUCKER C*NT!!! AAARGH"
Old Oct 21, 2004 | 02:30 PM
Farmer Giles's Avatar
Farmer Giles
Can you heat them up first to make them abit more plyable (spl) ???
Martyn
Old Oct 21, 2004 | 02:33 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
just had new ones on mine all new rivets all heated up just moved my car 3 bits of clips on the floor
Old Oct 21, 2004 | 02:39 PM
Jim Galbally
giles, tried that...
didnt work
Old Oct 21, 2004 | 02:48 PM
Farmer Giles
I have never seen these clips or rivets so don't know if this would work or not, but .......
Is it possible to flat the head of the rivet, top and bottom, so the clip will slid on horizontally and then rotate the clip 90 deg so it fits under the rivit on the remaining vertical bits of the head ??
Martyn
Old Oct 21, 2004 | 02:50 PM
Jim Galbally
nope
the rivet bit isnt a problem at all... its what holds the clip to the skirt
the clips are just that, clips... you push them onto the thin strip of metal that hangs down from the sill...
thing is the clips are NOT pliable! theyre v. stiff, and will snap VERY easily...
stupid bloody material to make a clip from!
Old Oct 21, 2004 | 03:01 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Take it to a body work place and let them have the hassle of fitting then jim
DOO's Avatar
DOO
jim are you useing the right sized clips there 3 diffrent sizes?
Old Oct 21, 2004 | 03:11 PM
Jim Galbally
doo, yep. i bought enought to do the whole car + a few spares (not cheap!)
and i only managed to get ONE SIDE done
Old Oct 21, 2004 | 03:23 PM
DOO's Avatar
DOO
Get some rouse skirts you get no probs with them
the amount of dosh you spent on stupid clips you could of bought a pair of skirts
Old Oct 21, 2004 | 03:40 PM
deleted's Avatar
deleted
my mate a the bodyshop just came up with a idea which may work undersealing the sill section where the clips go on thus giving them more adhesion we are gonna try that with mine
Old Oct 21, 2004 | 03:41 PM
CosKev3's Avatar
CosKev3
I made some small 'L' shape brackets out of light alloy,rivet them to skirts then
self-tappers into sill,job done
Old Oct 21, 2004 | 03:42 PM
Jim Galbally
yeah but surely that just makes em less likely to fall off, not less likely to snap?
Old Oct 21, 2004 | 03:50 PM
CosKev3's Avatar
CosKev3
What snap?????
Old Oct 21, 2004 | 03:52 PM
Jim Galbally
the clips on the sideskirts
Old Oct 21, 2004 | 04:04 PM
Smit's Avatar
Smit
The 60ft Launch King
Jim - these are a nightmare!
solution please!
Old Oct 21, 2004 | 04:17 PM
brad's Avatar
brad
you bunch of homo's
get a fucking heat gun , heat them up till they are litrally melting then push them on . once sitting in place drill tiny little holes and either rivet them on to the metal strip or use self tapping screws . we,v done dozens of them and dont have any problems
by the way if your worried about burning your ickkle pingy's with the heat gun WEAR SOME GLOVES
Old Oct 21, 2004 | 06:47 PM
CosKev3's Avatar
CosKev3
You REPLACE the plastic clip with the 'L' shape bracket
No clips to break
Jim Galbally
how can an L shaped bracket hold the thng up tho?
Old Oct 21, 2004 | 06:58 PM
Jim Galbally
i take it that stickerflex is quite strong then!
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
i sawed the spikes out of my clips and stickerflexd them on the sill non e ever broke
Old Oct 21, 2004 | 07:39 PM
CosKev3's Avatar
CosKev3
Have sent you an e-mail m8
Old Oct 21, 2004 | 07:48 PM
velocity's Avatar
velocity
i had the same snag while rebuilding my 4x4 so what i did was spend another heap of dosh bought a load more.but this time i filed back the v-ribs that grip the sill when pushed into position until they were a light fit on the sill.this worked out perfect.
Old Oct 21, 2004 | 09:43 PM
cossiemen's Avatar
cossiemen
Whassup
yep, these clips are fookin expensive.
had the same problem as Jim Galbally and the same solution; just gave up fitting them...
maybe someone has a final solution ??
Old Oct 21, 2004 | 09:54 PM
GUZZLER's Avatar
GUZZLER
changed my passenger side one (in front of rear jackpoint cover) about 5 times,
if it dosn't snap when your fitting it, then it snaps a few days later
in the end, i quicksteeled the remaining part of the clip to the sill, BODGE i
know,,,,,, but it has held for quite a while
Old Oct 21, 2004 | 09:59 PM
Ginge !'s Avatar
Ginge !
just finding my feet
well my solution is leave the fookers alone, stop looking at the sode skirts and all ya problems are solved
serious how cares as the kit aint gonna fall off is it
fooking bufty boys
Old Oct 21, 2004 | 10:05 PM
cossiemen's Avatar
cossiemen
Whassup
it's not a matter about being a bufty, i just want to fit them onto my car
she looks much much better with them skirts fitted
Old Oct 21, 2004 | 10:12 PM
GUZZLER's Avatar
GUZZLER
i like Gus's idea
Old Oct 21, 2004 | 10:15 PM
cossiemen's Avatar
cossiemen
Whassup
ermmmm... what does stickerflexd mean?
i'm :blonde: see?
Old Oct 21, 2004 | 10:17 PM
DOO's Avatar
DOO
Buy a Rouse problem sorted
Old Oct 21, 2004 | 10:18 PM
Ginge !'s Avatar
Ginge !
yeah but 4wd's for girls
i would buy a rwd rousde but there a bit harder to find
brad's Avatar
brad
ffs USE A HEAT GUN
Old Oct 21, 2004 | 10:19 PM
GUZZLER's Avatar
GUZZLER
Originally Posted by brad
ffs USE A HEAT GUN
thats ok for putting them on, but they always go brittle & snap after while.
Old Oct 21, 2004 | 10:25 PM
cossiemen's Avatar
cossiemen
Whassup
so no one knows what stickerflexd means ?
Old Oct 21, 2004 | 10:26 PM
brad's Avatar
brad
they are brittle anyway so by heating and bending(altering the shape) it relieves the stress on the front edge where they allways snap . and as i said earlier we use either small stainless rivets or self tappers once they're on . never had any probs with them
Old Oct 21, 2004 | 10:30 PM
Phil's Avatar
Phil
Jeebus
Heating them to melting point will leave them FAR more brittle once they have cooler down!!
Old Oct 21, 2004 | 10:34 PM
DOO's Avatar
DOO
Got some 2in wood screws PM me for details
Ginge !'s Avatar
Ginge !
think he ment silkoflex, like tiger seal, a really strong glue the chavs use on there novas to stick or bits and bobs they find in old ladys handbags to there car to make em look faster
