Fiesta XR2i 1.6CVH exaust and suspention
Old Mar 25, 2008 | 06:27 PM
cosworth87's Avatar
cosworth87
Default Fiesta XR2i 1.6CVH exaust and suspention
I am building a Fiesta XR2i 1.6CVH as a cheap track toy.
The things i cant figure out is the exaust. i bought the car with crappy exaust. so i tried to make something new from scratch by using 2" pipes and 2 Silencers.
But it Sounds CRAP and knocks innto the carbody.
So the only sulution is to get a new compleete exaust. like the Ashley http://www.fiesta-centre.co.uk/fiest...lpipe-17-p.asp
and the http://www.fiesta-centre.co.uk/fiest...-1992-26-p.asp
BUT.. will this be all needed to replace the cat? because all that was original fron under the crossmember is cut in peaces?
and can somebudy give a ca DB level on this exaust...
And also thinking aboud G-Max suspension.. but is it Crap? or god?
Sorry for bad english. from norway
Old Mar 25, 2008 | 08:23 PM
wildheart's Avatar
wildheart
G-MAX is very bad.
Had it fitted to mine and after a few weeks a spring platform snapped!!!!
Old Mar 25, 2008 | 09:00 PM
cosworth87's Avatar
cosworth87
Then i think the 4 or 5 year old H&R springs and dampers allready on the car is fine....
enyone on the exaust?
Old Mar 25, 2008 | 09:09 PM
XR2's Avatar
XR2
Forget the ashley. Fucking loud and gives less power than a Scorpion or a Mongoose.
Buy yourself a stainless manifold and a stainless system. Will give you much more than 100 dB. Think you want to use it on an race track and have limitations for the dB?
Then just weld in another silencer
Old Mar 25, 2008 | 09:19 PM
XR2's Avatar
XR2
My setup:
CSC Grp.A manifold (from ebay, no longer available iirc)
Scorpion stainless exhaust
The old one was an ashley manifold. Broke three times
Old Mar 25, 2008 | 09:50 PM
cosworth87's Avatar
cosworth87
i ned it to be under 100.. issent there eany complete systems giving that db level??
Old Mar 25, 2008 | 10:25 PM
XR2's Avatar
XR2
mainly standard ones. But that will limit the power output...
Old Mar 25, 2008 | 11:24 PM
cosworth87's Avatar
cosworth87
Yes i dont want original. car got Kent Cam. and a green filter from a bmw 525i? that should be big enough?
But how bad is the Asley exaust system not the manifold?
the ashley is a complete system from downpipe?
Old Mar 25, 2008 | 11:27 PM
cosworth87's Avatar
cosworth87
Your car is a Mk2 mine is a Mk3. meybe there will be some noise differences?
because on the mk3 im were shoure it got 2 silencers
Old Apr 9, 2008 | 08:23 AM
cosworth87's Avatar
cosworth87
The exaust Rallydesign sells with manifold from rallydesign. are they eany good??
Spax suspention?
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
