best rst clutch?
Old Mar 25, 2008 | 05:16 PM
sidewaysdave's Avatar
sidewaysdave
Default best rst clutch?
hi my rst has a brand new clutch fitted (100miles old) but its started slipping in 3rd ,fitted a new clutch cable but still slips, dont no bhp its running but its booked into tourqe of the devil in 3 weeks time and i need to sort it also if i take it easy till the cars been running for 10 mins or so it dont slip?
Old Mar 25, 2008 | 05:44 PM
grsford's Avatar
grsford
ap 4 paddle with standard cover works fine
Old Mar 25, 2008 | 07:41 PM
flashpoint's Avatar
flashpoint
a lot if the clutch slips or not depends no how you drive it... what clutch are you using at the moment..
Old Mar 26, 2008 | 08:34 AM
kevbnicpp's Avatar
kevbnicpp
Thumbs up
I've just done this and it worked for me (180-200 bhp estimated power)
same pedal feel,better bite little bit of shudder that doesn't bother you.
what power are you running grsford?
Old Mar 26, 2008 | 06:31 PM
sidewaysdave
im using a stardard clutch but the car is being set up and chiped at touque of the devil on 11th of april and i dont want there to be any problems i cant understand why if i take it easy for 10 mins then drive it hard i get no slip??
Old Mar 26, 2008 | 08:05 PM
flashpoint's Avatar
flashpoint
Hi it can take quite some time for the clutch to bed in, you say you have done 100 miles but how were those miles done,was the fly wheel skimmed when the clutch was fitted. all can have a bearing no how the clutch will perform? It's possible that when the clutch is cold that the friction material on the drive plate is not gripping as well as when it is worm?
Old Mar 26, 2008 | 10:02 PM
grsford's Avatar
grsford
240hp
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
A.t.p
Oct 23, 2015 07:54 PM
