help needed fitting k&n induction kit
Went to fit a K&N induction kit to my cosworth today and noticed two hoses going into the standard air box. When i fit the induction kit what do i do with these hoses?
thanks
thanks
one is the oil breather will be fine to leave it go to atmosphere!you can get a little filter if u want to put on this pipe the other comes from the amel valve again fine to leave to atmosphere!
The pipercross has flanges for the 2 pipes to join to, if ya still want to use them.
I have a k&n grp A cone on mine and as above the pipe from the amel valve is to atmosphere and i stuck a small k&n filter on the breather pipe at front of cam belt cover.
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
