using a different box and tranny
Old Mar 24, 2008 | 02:41 PM
gaz_turbo1's Avatar
gaz_turbo1
Cool using a different box and tranny
right thought if i was to get a answer from anyone on this it would be on here,
i have a ep85 starlet 4wd and want to put a fair bit of power through it, but i can't see it holding up all that well, would it be possible to use the rear axle from a celica gt4 and try and use the gearbox and transfer box, i no alot of parts will have to be custom made but would it work??
cheers
gaz
Old Mar 24, 2008 | 03:24 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
no reason why not!
Old Mar 24, 2008 | 04:14 PM
gaz_turbo1's Avatar
gaz_turbo1
the only problem i could see is getting the box and transfer box on and getting the prop lined up to the centre of the rear diff, and one got any links or anything like this?
Old Mar 25, 2008 | 05:31 PM
gaz_turbo1's Avatar
gaz_turbo1
anyone?
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
