Should i sell it?
Im thinking of selling my S2 its on
a 86 D plate,shell is solid with no rot round the sunroof,battery tray,scutte or slam panel,its had a new camshaft fitted,was given a recon turbo wen i got it? but cant prove this.Its on stardard wheels but ive got some RS 7 spokes 16'' to go with it,its had new track rod ends an bottom arms.koni front struts.Tidy interior with a v good cond cossie steering wheel,cossie front calipers an disks.Ive also got an ofab loom with all the sensors,efi inlet manifold,the bottom end is a efi item so has the cps hole in it,im gettin the ofab ecu and efi head soon,ive also got a new water pump, new altanater.Ive also got a avital max 1 alarm new in box with certifacate for insurance,and fitting insructions(made by clifford)
Bad bits...It needs piston rings so i was going for a bottom end rebuild,some chips in the paint here and there,stater motor is tempramental
So wot do u guys think i should do? at the moment im just fed up with the rs
i have a silmilar issue, got a red D plater loosk a treat obv had welding but its genuine 80k and its pretty godo on teh whole
but do i sell cos its been in warm/dry store for 5 years now and only getting rarer
its no minter so i figure its worth £1500 with a years on it
Mark RS
Oct 12, 2015 06:01 AM
