oil cooler leaking
Old Mar 20, 2008 | 07:14 PM
cossie.con's Avatar
cossie.con
Angry oil cooler leaking
hi guys i have noticed that i have a consistent oil leak from my oil cooler where it meets the block is this a machined surface or does it require a gasket or sealer help much appreciated
Old Mar 21, 2008 | 11:49 AM
Aaroncast's Avatar
Aaroncast
-try one anyhow -machined or not!!!!!!!!!!!!!!!!
Old Mar 21, 2008 | 06:37 PM
They have a oil seal as std if modine type.
Old Mar 21, 2008 | 06:46 PM
velocity's Avatar
velocity
Old Mar 21, 2008 | 06:50 PM
velocity's Avatar
velocity
these are the parts required for a 4x4 set up but the block to oil cooler seal should be the same for the 2wd
Old Mar 21, 2008 | 08:57 PM
cossie.con's Avatar
cossie.con
Talking
thanks for the replys guys i see my mistake now pics really helped cheers
Fudgey
21
Sep 30, 2015 06:19 PM
