Cosworth 4x4 Oil Pump Fitting
Old Mar 20, 2008 | 06:09 PM
ickey818's Avatar
ickey818
Default Cosworth 4x4 Oil Pump Fitting
Currently changing the oil pump on my 4x4 Cossie, have brought a sump gasket set which included all the gaskets for the oil pump.
I have the gasket for the pick up pipe to the oil pump but there is also an O ring with this, can someone tell me where this should be fitted?
Also I don't have a gasket for the oil pump to cylinder block joint, should this be sealed with wet sealer or is it just a metal to metal contact?
Old Mar 21, 2008 | 09:27 AM
PGT's Avatar
PGT
there is no gasket between the pump and the block - just al to steel as you say. the o ring may be for a 2wd pump / spray jets which has a ring between the pump body and the piston spray jet pipe. this pipe is about 6mm diameter for reference
big_Rad
Sep 15, 2017 09:36 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
