any help please!
Old Mar 19, 2008 | 10:15 PM
YBT200's Avatar
YBT200
Default any help please!
hi, i have an 94 escort cosworth large turbo with a/c and i want to remove the timing belt cover, i removed all the screws but it seems it can go out of the place because of the a/c motor ! any help about removing it in place please !
many thanks
Old Mar 20, 2008 | 07:41 PM
YBT200's Avatar
YBT200
anyone had this problem please!!!!!!!!!!!
Old Mar 21, 2008 | 07:34 AM
GUZZLER's Avatar
GUZZLER
there a bit tricky with a/c, normally i pull the cover upwards & fowards (keeping a bit of lifting pressure on it) then give it a bit of a wiggle, they normally come out then.
Old Mar 22, 2008 | 06:28 PM
YBT200's Avatar
YBT200
thanks mate i will try again !
Old Mar 22, 2008 | 07:27 PM
THE RADMAN's Avatar
THE RADMAN
they are a total pain,you can easily end up cracking it,good time to replace with a cut down version,2 min job then in the future,lol
Old Apr 3, 2010 | 10:26 AM
YBT200's Avatar
YBT200
i have removed it but now i need to fit it again and it seems to be impossible to put it back in place any hits or help please ??
Old Apr 5, 2010 | 01:59 PM
YBT200's Avatar
YBT200
any help !!
Old Apr 5, 2010 | 02:02 PM
rsnissan's Avatar
rsnissan
remove the AC tensioner, its quicker in the long run and saves damaging the cover
Old Apr 6, 2010 | 04:43 PM
YBT200's Avatar
YBT200
i taught so , thanks i will try again !
