escos spec and power
Old Mar 19, 2008 | 06:08 PM
turbostarkie's Avatar
turbostarkie
shagger
Default escos spec and power
hello all what kind of power range am i lookin for on the dyno had it at 380 last time but runnin more boost bigger injectors lookin for 450 ish spec as follows
escort cosworth spec
wire rung 200 block
fully lightened and ballanced
ARP bottom end
t38 hybrid holding 33 psi
bd 14 and bd 10
matched inlet to head
msd closed loop
custom 70mm inter cooler
piper verniers
external group a fuel pump
group a coil
je forged pistons
mongoose from turbo
gray injectors
motorsport leads
adjusable fuel pressure regulator
group a gaskets and belts
alcon 6 paddle clutch
group a k and n filter
Old Mar 19, 2008 | 06:12 PM
bigchez's Avatar
bigchez
Not sure if greys will fuel to 450 fella. Looks a good spec tho.
Old Mar 19, 2008 | 06:17 PM
turbostarkie
shagger
f
Old Mar 19, 2008 | 07:08 PM
rapidcossie's Avatar
rapidcossie
needs to run 370 ATW ish to be 450 fly
Old Mar 19, 2008 | 10:02 PM
NEIL A's Avatar
NEIL A
think harvey's engines make about 430 bhp at 27 psi on greys,from what i have heard that is them nearly maxed out without upping the fuel pressure on greys. Going from Duncoss and Ripleys engines.
Old Mar 19, 2008 | 10:09 PM
Billabong's Avatar
Billabong
Who's Harey, lol.
Mine made 451 (engine dyno) @ 26psi.
Old Mar 19, 2008 | 10:10 PM
rapidcossie
I meant it will need to run 360 ish ATW at AVA Fraser as I think charlie shaw's old Harevy 450 dyno engine made 360 ish ATW at AVA.
Old Mar 19, 2008 | 11:10 PM
black scoob's Avatar
black scoob
going on that basis the scoob mustnt have made as bad power as i thought when it first went to ava and got 382 atw....must be about 460bhp?
Old Mar 20, 2008 | 12:02 PM
rapidcossie
yeah scott but had a pretty poor power curve that peaked at 6k then feel on its ass
Old Mar 20, 2008 | 01:06 PM
Smoker's Avatar
Smoker
that spec should easily see 450bhp
Old Mar 20, 2008 | 06:01 PM
turbostarkie
shagger
thank you all for the input soon to go back on dyno soon see lol
Old Mar 20, 2008 | 08:27 PM
black scoob
curve wasnt that bad up to 6k, just pish after it....
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stevecfrst1
Sep 30, 2015 05:18 AM
